2007 Hyundai Entourage GLS, Engine/Propulsion Waveform
This is a partially jammed Delphi VVT solenoid (it "ate" its oil screen). This solenoid audibly "clicked" when manually tested via jumper wire to ground, but didn't seal. Note the slight hump in the blue amp waveform at point 1130. Red is control side volts, t...
2007 Hyundai Entourage GLS 3.8L
