1996 Kia Sephia GS, ECM/Inputs/Outputs Waveform
Scope trace showing CKP / CMP sync along with IC signal. Ignition timing was visually verified so the sync should be close. The coil firing is causing inteference in both signals.
| Condition | Unknown |
1996 Kia Sephia GS 1.8L
