1993 GMC Sonoma, Ignition Waveform
Posted to the Waveform Library on 3/19/2015
(GREEN) Distributor Hi Reference or RPM (BLUE) Ignition Control. The ignition control module ICM is bad. It is a cardone, go figure. The RPM signal is produced by the distributor and sent to the ECM. Then the ECM sends out signal for IC to take over. The ...
1993 GMC Sonoma 4.3L
Engine4.3 L / 6 cyl / GAS
Trans5-speed StandardTransmission
SubsystemIgnition
SubsystemIgnition
