2005 GMC Sierra 1500, ECM/Inputs/Outputs Waveform
Vehicle was a crank/ no start and run but cut out. Setting P0335 and P0336. Found CMP Sensor shorting 12 ref, which is shared in the PCM, to 3 volts. This capture was taken after new CMP installed and vehicle is running. Both signals now switching to 12 volts.
| Engine | 4.8 L / 8 cyl / GAS |
2005 GMC Sierra 1500 4.8L
