1991 Honda Accord, IC Circuit Waveform
This image of the timing control signal was taken during a no start condition, also the timing control signal wire was removed from the ICM connector to see if the ICM was causing the erratic signal. See [image8132]
1991 Honda Accord EX 2.2L
