check carefully
Body Wire Harness (1) for cuts and chafes from being pressed against the Instrument Panel Carrier (2) when the driver side Instrument Panel Insulator Panel is installed. The area is located near C203 I/P Harness to the Steering Column Harness (3) and over the ...
