2007 Subaru Impreza WRX Limited, Ignition Waveform
2007 Subaru Imprezza WRX 2.5T DOHC w/ MT -- White is the crankshaft position sensor and yellow is the PCM to ICM signal for cylinder #1's ignition coil. In this capture the coil is disconnected.
| Engine | 2.5 L / 4 cyl / GAS |
2007 Subaru Impreza WRX Limited 2.5L
