2000 Mercedes-Benz ML320, Engine/Propulsion Waveform
2000 Mercedes ML320 3.2L -- Channel 1 is a relative cranking compression test and channel 2 is a vacuum transducer attached to the intake manifold. Fuel pump has been disabled and engine is cranking.
| Engine | 3.2 L / 6 cyl / GAS |
2000 Mercedes-Benz ML320 3.2L
