2000 GMC W3500 Forward W3S042, Engine/Propulsion Waveform
2000 GMC W3500 5.7L VIN R -- Channel 1 (blue) is a pressure transducer in cylnder #3, channel 2 (pink) is a Dx (vacuum) transducer on the intake where the vacuum booster line would go, channel 2 (gold) is a relative cranking compression test, and channel 7 (gr...
| Trans | 0-speed AutomaticTransmission |
2000 GMC W3500 Forward W3S042 5.7L
