2000 GMC W3500 Forward W3S042, Engine/Propulsion Waveform
2000 GMC W3500 5.7L VIN R -- Channel 2 (pink) is a Dx (vacuum) transducer in the dipstick tube, channel 2 (gold) is a relative cranking compression test, and channel 7 (green) is an inductive pickup around cylinder #3's ignition cable. The firing order is 1843...
| Trans | 0-speed AutomaticTransmission |
2000 GMC W3500 Forward W3S042 5.7L
