1997 Honda Accord LX, Engine/Propulsion Waveform
1997 Honda Accord LX 2.2L -- Blue is a running compression waveform from an in-cylinder pressure transducer, pink is an inductive pickup around cylinder #4's grounded ignition cable (through spark tester), and green is a Pressure Pulse Sensor on the PCV nipple...
