2006 Ford F-150 STX, Engine/Propulsion Waveform
2006 Ford F150 4.2L V6 -- Channel 1 (blue) is a pressure transducer in cylinder #4, channel 2 (pink) is a vacuum transducer (Dx) on the purge line nipple directly behind the throttle body, and channel 3 (gold) is a relative cranking compression trace. Ignition...
| Engine | 4.2 L / 6 cyl / GAS |
2006 Ford F-150 STX 4.2L
