variable dwell, vacuum advance distributor
Posted to the Waveform Library on 3/24/2014
Simple system: nichrome resistor wire to coil B and coil B- to contact points and condenser. Note ground wire from breaker plate to distributor housing. Special cam lube is used on contact point rubbing block. Distributor mechanical advance oils via felt ...
