2003 Hyundai Santa Fe GLS, Engine/Propulsion Waveform
2003 Hyundai Santa Fe 3.5L w/ AT -- White trace is a relative cranking compression test, and pink is a Pressure Pulse Sensor on the brake booster nipple on the intake manifold. Engine was disabled by disconnected the CKP, and the engine was cranking in this c...
| Engine | 3.5 L / 6 cyl / GAS |
2003 Hyundai Santa Fe GLS 3.5L
