1998 Dodge Ram 1500 ST, Engine/Propulsion Waveform
Engine has a dead miss at idle. Cranking vacuum test with first look sensor, and synch on cyl 1 ignition. Intake valve sealing issue on cylinder 6. Showing how it affects cyl. 4 vaccum pull.
| Engine | 5.2 L / 8 cyl / GAS |
1998 Dodge Ram 1500 ST 5.2L
