1998 Volkswagen Jetta GL, Ignition Waveform
Posted to the Waveform Library on 2/10/2014
1998 VW Jetta 2.0 ABA -- Two waveforms superimposed for comparison purposes. White is voltage to the coil, pink is current in the coil circuit, yellow is ECM to ICM signal, and green is a capacitance pickup around the coil wire. The coil wire is grounded to th...
1998 Volkswagen Jetta GL 2.0L
Engine2.0 L / 4 cyl / GAS
Trans5-speed StandardTransaxle
SubsystemIgnition
Component,
SubsystemIgnition
Component,
