1998 Volkswagen Jetta GL, Ignition Waveform
1998 VW Jetta 2.0 ABA -- White is voltage to the coil, pink is current in the coil circuit, yellow is ECM to ICM signal, and green is a capacitance pickup around the coil wire. The coil wire is grounded to the distributor shaft. The distributor cap and rotor...
1998 Volkswagen Jetta GL 2.0L
