1996 Toyota Camry LE, ECM/Inputs/Outputs Waveform
1996 Toyota Camry 3.0 V6 -- Yellow is fuel injector #5 drive from PCM, green is a low amperage probe around fuel injector #5's power feed, and red is a Pressure Pulse Sensor hooked to the vacuum nipple of the fuel pressure regulator. Vehicle is running at idl...
1996 Toyota Camry LE 3.0L
