1996 Toyota Camry LE, ECM/Inputs/Outputs Waveform
1996 Toyota Camry 3.0 V6 -- Output of the CSS Script when the engine is running normally. Script shows cylinder #5 has low contribution through out all conditions except deceleration. That portion of the graph, where all cylinders are equal, is demonstrating...
1996 Toyota Camry LE 3.0L
