1996 Toyota Camry LE, ECM/Inputs/Outputs Waveform
1996 Toyota Camry 3.0 V6 -- White is coil current, pink is primary trigger for that coil, yellow is an inductive pickup around the ignition cable, and blue is a capacitance pickup around the ignition cable. The capture shows a lean event in this cylinder.
1996 Toyota Camry LE 3.0L
