1996 Toyota Camry LE, ECM/Inputs/Outputs Waveform
1996 Toyota Camry 3.0L V6 -- Purple is fuel injector #5 drive from PCM, and white is a low amperage current clamp around the injector feed for fuel injector #5. This injector is drawing approx 100mA.
1996 Toyota Camry LE 3.0L
