2000 Acura TL, Engine/Propulsion Waveform
2000 Acura TL 3.2L V6 -- Pink is a Pressure Pulse Sensor on the PCV nipple on the intake manifold, yellow is a relative cranking compression test, and green is the PCM to coil #1 primary trigger. Fuel system was disabled.
| Engine | 3.2 L / 6 cyl / GAS |
2000 Acura TL 3.2L
