1996 Toyota Land Cruiser, Ignition Waveform
1996 Toyota Land Cruiser 4.5L -- Yellow is a capacitance pickup around the ignition coil wire and green is an inductive pickup around cylinder #1's ignition cable. The misfire is present in the capture. This vehicle had a bad spark plug in cylinder #4.
| Engine | 4.5 L / 6 cyl / GAS |
