2004 Mazda MPV ES, Engine/Propulsion Waveform
2004 Mazda MPV 3.0L VIN A -- Channel 1 (white) is a Firstlook Sensor in the exhaust, and channel 2 (pink) is the primary drive for cylinder #4's ignition coil. Capture is taken at idle. Vehicle had a very intermittent misfire only at idle. No codes stored. Th...
2004 Mazda MPV ES 3.0L
