2001 Dodge Grand Caravan ES, ECM/Inputs/Outputs Waveform
2001 Dodge Grand Caravan 3.8L V6 -- Yellow is ignition switch output to Leak Detection Pump, green is LDP solenoid control, and blue is LDP switch sense. This capture was taken while running the EVAP System Test. The vehicle was setting a P0455 due to an EVA...
2001 Dodge Grand Caravan ES 3.8L
