1993 Acura Legend, Ignition Waveform
![]() ![]() 1993 Acura Legend 3.2L w/ AT -- Yellow is ICM to coil #6 drive signal, green is ECM to ICM command for cylinder #6, blue is a FirstLook Sensor in the exhaust, and red is a low amp current probe around the power feed for coil #6. Engine is idling and a misfire...
Engine | 3.2 L / 6 cyl / GAS |
Subsystem | Ignition |
Component | , |
Condition | Known Bad |
Component | , |
