Low Compression While WOT Cranking
This was the visual result shown to a customer with a compression gauge after doing relative compression tests and while using a FLS in the exhaust while cranking showing the same cylinder and problem on a 06 Ford F-150 5.4L as the gauge did. Using a gauge is ...
