2004 Dodge Durango SLT, Engine/Propulsion Waveform
2004 Dodge Durango SLT 4.7L V8 VIN N -- Yellow is a relative cranking compression test. Red is primary trigger for cylinder #1. Green is a WPS 500 in cylinder #7. Purple is the camshaft marked out based off of the primary ignition trigger. Firing order is ...
| Engine | 4.7 L / 8 cyl / GAS |
TECH: Compression Waveforms, Part 12
TECH: Cyl. 4 misfire
TECH: odd cranking wave form
TECH: the good,bad and ugly(dry humor)
TECH: Changed plugs, lost all compression, regained all but #6
TECH: Cranking Amperage test
THEORY: compression test
THEORY: Another pressure transducer case study
THEORY: Glitch in exhaust pocket
