Pitman Arm Straightening Driveshaft Yoke.
Posted to the Waveform Library on 2/14/2013
If you accidentally bend a drive shaft yoke and only discover it during install of the new u-joint. It can be carefully straightened with the clips installed, an appropriately sized socket and a pitman arm puller.
