1996 GMC C6000 Topkick C6H042, Engine/Propulsion Waveform
1996 GMC C6000 Topkick w/ 7.0L V8 -- Yellow is a relative cranking compression waveform and green is a capacitance pickup around cylinder #1's ignition cable. The fuel pump is disconnected and the engine is cranking. A vacuum gauge flutters heavily at idle (...
| Engine | 7.0 L / 8 cyl / GAS |
| Trans | 0-speed AutomaticTransmission |
| Condition | Unknown |
1996 GMC C6000 Topkick C6H042 7.0L
