1999 Chevrolet Camaro, Engine/Propulsion Waveform
1999 Chevrolet Camaro 3.8L V6 VIN K w/ MT -- Capture taken at idle with misfire present. Yellow is a WPS500 (setting 3) in the exhaust pipe, and purple marks out the cylinders. The left most purple line is where cylinder #6's ignition strike would be. The f...
