1997 Honda CR-V LX, Engine/Propulsion Waveform
1997 Honda CRV 2.0L w/ AT -- Red is MAP sensor signal, blue is an inductive pickup around cylinder #1's ignition cable, and purple marks out the cylinders. The fuel pump is disconnected and the engine is cranking.
1997 Honda CR-V LX 2.0L
