1997 Honda CR-V LX, Engine/Propulsion Waveform
1997 Honda CRV 2.0L w/ AT -- Yellow is a FirstLook Sensor on the brake booster nipple on the intake manifold, red is MAP sensor signal, blue is an inductive pickup around cylinder #1's ignition cable, and purple marks out the cylinders. The fuel pump is discon...
1997 Honda CR-V LX 2.0L
