2008 Ford F-150 XLT, ECM/Inputs/Outputs Waveform
Ford F150 2008 5.4l 3V. The blue line is the 5V REF at the PCM pin feeding the FRTP sensor and the PS [...] red line is the FRTP signal. The 5V shorts to ground intermittently while driving. This drop cause the FRTP to drop his signal too, telling the Fuel pum...
2008 Ford F-150 XLT 5.4L
