2002 Ford Escape XLT, Engine/Propulsion Waveform
2002 Ford Escape XLT 3.0 V6 w/ AT -- Yellow is a relative cranking compression test, red is coil #4 primary drive, blue is a pressure transducer in cylinder #4, green is a Firstlook Sensor in the dipstick tube, and purple is marking out the cylinders. This ca...
2002 Ford Escape XLT 3.0L
