2002 Ford Escape XLT, Engine/Propulsion Waveform
2002 Ford Escape XLT 3.0 V6 w/ AT -- Yellow is a relative cranking compression test, red is coil #4 primary drive, green is a Firstlook Sensor in the intake, and purple is marking out the cylinders. This capture was taken cranking with the inertia switch disc...
2002 Ford Escape XLT 3.0L
