1993 Honda Civic del Sol Si, Engine/Propulsion Waveform
1993 Honda Civic del Sol 1.6L D16Y8 -- Yellow is a pressure transducer in cylinder #1, red is a inductive pickup around the ground #1 ignition cable, and purple is marking out camshaft position. Engine was cranking and fuel injectors were disconnected. This ...
1993 Honda Civic del Sol Si 1.6L
