1997 Honda Accord LX, Engine/Propulsion Waveform
1997 Honda Accord LX 2.2L w/ AT -- Yellow is a relative cranking compression test taken with coil disconnected, taken at the battery negative with a high amperage clamp. Green is a pressure transducer in cylinder #1. Unfortunately the clamp is somewhat noisy...
