2004 Ford Ranger XL, Engine/Propulsion Waveform
2004 Ford Ranger 3.0L VIN U w/ MT - Yellow a capactive pickup on cylinder #4's igntion cable, green is the primary drive for coil 4/3, and blue is a low amp clamp around the common coil feed. Capture is taken at idle with a misfire. This is a power spark cap...
2004 Ford Ranger XL 3.0L
