2004 Ford Ranger XL, Engine/Propulsion Waveform
2004 Ford Ranger 3.0L VIN U w/ MT - Yellow is a high amperage clamp around the negative battery cable, and green is a pressure transducer in cylinder #4. Engine is cranking with the coil disconnected.
2004 Ford Ranger XL 3.0L
