2005 Ford F-150 XL, Engine/Propulsion Waveform
2005 Ford F150 5.4L SOHC 3 valve -- Yellow is primary drive for ignition coil #1, red is a high current amperage clamp around the battery negative cable, and green is a Firstlook Sensor in the brake booster hose where the check valve would go. The vacuum port...
2005 Ford F-150 XL 5.4L
