2008 Chevrolet Aveo LS, ECM/Inputs/Outputs Waveform
Here is a cam crank sync waveform showing the difference when the timing is incorrect versus being correct, it also shows the in-cylinder pressure difference when the timing is effected.
2008 Chevrolet Aveo LS 1.6L
