2006 Chevrolet HHR LT, Engine/Propulsion Waveform
2006 Chevrolet HHR 2.2L 4 CYL -- Vehicle had an intermittent ignition related misfire on cylinder #3. Yellow is the camshaft position sensor signal, red is a capacitance probe on cylinder #3's boot with an extension, green is the 3/2 (IC 2) coil primary drive...
TECH: Firstlook Sensor waveforms, part 10, FLS vs. WPS again
TECH: My first good look at exhaust pressures
TECH: Firstlook Sensor waveforms, part 13, quick refresher
THEORY: pressure pulses while misfiring
2006 Chevrolet HHR LT 2.2L
