1995 Geo Metro, Engine/Propulsion Waveform
1995 Geo Metro 1.0L 3 CYL - Yellow is a capacitive pickup on the coil wire, red is an inductive pickup around cylinder #1 ignition cable, and green is a Firstlook Sensor in the exhaust. Cylinders are marked in purple. This capture was taken at idle with an o...
| Engine | 1.0 L / 3 cyl / GAS |
1995 Geo Metro 1.0L
