1989 Chevrolet Celebrity, Engine/Propulsion Waveform
1989 Chevrolet Celebrity V6 2.8L - Yellow is secondary ignition at cylinder #1 wire, red is a current probe around the pink wire feeding the ignition coil assembly, green is voltage on the same pink wire, and blue is EST taken at the module connector. This ca...
| Engine | 2.8 L / 6 cyl / GAS |
1989 Chevrolet Celebrity 2.8L
