2006 Ford Focus ZX4, Engine/Propulsion Waveform
2006 Ford Focus ZX4 2.0L VIN N - Running compression test at idle for cylinder #1. Yellow is crankshaft position sensor signal, green is a pressure transducer in cylinder #1, blue is camshaft position sensor signal, and red is coil #1 primary drive. Coil is ...
