1997 Ford Ranger XL, Ignition Waveform
1997 Ford Ranger 4.0L V6 VIN X - Engine under power brake. Intermittent misfire under load. Yellow is an amp clamp around coil primary feed, green is primary ignition for the 1/5 coil, and blue is a secondary lead pickup on the #5 ignition cable. This vehic...
| Engine | 4.0 L / 6 cyl / GAS |
1997 Ford Ranger XL 4.0L
