1993 BMW 740iL, Engine/Propulsion Waveform
1993 BMW 740iL V8 - Firing order 15486372. Yellow is primary ignition on cylinder #5 coil. Green is a Firstlook Sensor in the exhaust. Engine is running at idle. #5 ignition coil has a spark plug tester in the end of it.
| Engine | 4.0 L / 8 cyl / GAS |
1993 BMW 740iL 4.0L
