2000 Ford F-150, Engine/Propulsion Waveform
2000 Ford F150 5.4L VIN L - Intermittent subtle misfire at idle. Yellow is primary ignition for cylinder #1, green is a Firstlook Sensor in the exhaust, blue is an amp clamp around the common coil power feed, and red is fuel injector #7 drive. This capture i...
| Condition | Unknown |
2000 Ford F-150 5.4L
