1989 Pontiac Bonneville LE, Engine/Propulsion Waveform
1989 Pontiac Bonneville 3.8L V6 - Yellow is secondary ignition on cylinder #4 ignition cable, green is a Firstlook Sensor in the brake booster hose, blue is a pressure transducer in cylinder #3, and red is an amp clamp around the negative battery cable. This ...
| Condition | Unknown |
1989 Pontiac Bonneville LE 3.8L
